UTV as a compact truck
By SpaceGhost
By SayHiToRambo
08 trooper 1100
thanks!
By boydog40
thanks guys
By Jacob E freeman
By Texjpr
2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
