    • By Mark T
      MY 400 is gutless. I would like to know if I can upgrade to a larger engine ?
    • By buckrub
      Hey guys! Newbie here. I'm an old man who's better with plowing a mule (4-legged kind) than these newfangled beasts. I, and a friend of mine, just bought new Coleman sxs and are having to finish the assembly. I've been reading on this site and I'm falling on the mercy of you experts. The only way I'm an expert is that an "ex" is a has been, and a spurt is a drip under pressure. LOL First off, the 2 buggies have no ignition switches. They seem to mount on the dash, not the opening in the steering wheel shaft cover, so we ordered new ones that are supposed to fit. They are 8 inches long, and have a 4-wired white plugin which is slightly rectangled when looking at the end of the plug. The trouble is there's nothing to plug into. There is a three-wire grey plug close enough to reach the four-wire plug, but of course, they are not compatible.
      Secondly, the blinker, light, ect. unit on steering wheel just spins around when touched. I see no way in heaven or earth to secure it. I've looked at a diagram on the Powersports site, but can't detect how it mounted. Fellows I'd be so grateful for any help with this. Me and my mule will even plow your garden for free, for your help. LOL
    • By Owenhacker
      So I have disassembled and installed a new wet clutch all new bearings, regreased primary and once I got it all back together it starts and dies as soon as I put in gear.. took apart twice to make sure everything is correct. Need help
      IMG_9111.mov
    • By Dreaded
      This tboss 410 started having a problem with I think clutch not releasing. If you have it in forward with neutral safety disabled and try to turn it over, it will try to move forward. Neutral does work correctly.
      What I was told occurred was he was trying to back up a hill and was trying to pull a load. He said that it all of sudden died and would not go into gear. To get it back he disabled the neutral safety and started engine and drove back but had to switch to neutral to stop.
      Is this going to be the centrifugal clutch on the drive belt or could it be something else?
    • By Hisun .500
      So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
