Totally Brand New to the World of UTV's
Anyone out there have a street legal UTV? Any idea how to get one registered for on highway use?
Thanks in advance
By Michigan sport.
I'm sure many of you are aware of Michigan's emergency brake requirement. I'm wondering if anyone has a good solution.
Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to the Maverick sport rear mounting bracket?
By Fishing Wiskers
By Farid
Hey there,
I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
Also, if you’ve got any other parts for this model, I’d love to hear about them!
Thanks a lot!
