I'm selling my Trooper, I'm asking 5000.00 for it below is a list of things I have done to it.
1. Differential upgrade kits front & rear
2. I have rewire the whole buggy accept the engine wiring harness going to the injector. I used the MINI FUSE AND MICRO RELAY RTMR PANEL BUSSMANN box with the Delphi weather-pack connector http://www.waytekwir...ONNECTOR-TOWER/ http://www.waytekwir...CRO-RELAY-RTMR/
3. silvlerbullet high performance cams
4. new rod ends on the a- arms
5. DieHard Advanced Gold AGM Battery - Group Size 34
6. Mile marker pe4500 winch on a winch cradle with ANDERSON CONNECTOR HOUSING SB 175 SERIES 600V with quick disconnect fittings and it is wire in the back to put in the 2" receiver to used it in the rear
7. Wheel bearing upgrade
8. unsteer power steering
9. oil cooler
10. surge tank
11. muffler
12 . wind shield from PACIFIC EAGLE USA
13. mud flaps
14. I have remove the plastic cover on the tilt bed and replace it with expanded metal mesh
15. Accel super pack coil
16. Belden EDGE spark plug wires
17. new gauges
18. silverbullet fuel controler
19. Innovate Motorsports Digital MTX Series Air/Fuel Ratio Gauge
20. manual 4x4 and I'm sure I'm forgetting something
    • By KimAC
      -Kim
    • By tskm
      Tom
    • By Xov
    • By Reynolds Rocket
