Lenny - thanks for sending this out. Next time I have to replace the clutch I will look into doing this. It definitely couldn't hurt by having a little stronger fork in there. Take care.
Original post was deleted by mistake so I'm reposting it. The fork that disengages the clutch by pushing on the throw out bearing is a little weak on the Trooper. There have been some failures. If you redo your clutch with a stronger pressure plate be sure to reinforce it. I've included a drawing which will give you an idea of what the reinforcement should look like. Just be sure that everything clears when it is actuated.
EDIT: Thank you Lenny, Kinarfi
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Greg Kilgore
