Yesterday , I bought an Axis xs750.  The doors were fine yesterday but today neither do will open from the inside (works fine from outside). Since it is both sides-is it a setting ? Did I do something ?  Help! :)
    • By Bobbers
    • By Marie
    • By D MAYNARD
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
