Front CV shaft
By Red Good
Serial # a8mv86futja001002 , no search engine will give me a model , it has a 471 engine . Is massimo always hard to get hold of ? No answer to emails or phone calls ?
By Isaac
I have a 2013 odes dominator when I get in it. It ideals fine but when you give it gas it bogs and goes and bogs and won’t go passed 30 can anyone help me
By mac66
By Alien10
A while back I was looking at an auction UTV plow and the mounting of it. Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV. I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn. I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place. The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
Anyone ever try this for a front mount? It would be close to this one that is for sale on the net. It is supposed to fit a KFI plow mount.
By Buck
My father-in-law has a Hisun 750. It has started to not change gears while running. He can turn it off, change gears, then restart and it will change. I thought it might have something to do with the brake but can’t find any info. Thanks in advance for any info.
