Hello,
I have just picked up a Mule 550 and am trying to get it running. It is getting fire and I have cleaned the tank and carb...the main issue I havn't figured out is fuel has been getting into the gas tank. I have changed the oil twice.
I bought a new fuel pump as the other one seemed weak. I am not sure it is hooked up right but it is hooked up the way it makes the most sense to me....one line comes from fuel tank and hooks into the side of pump pointing to the passenger side of utv...another valve pointing to back of utv has a fuel line that hooks directly into the top of the motor under the dump bed (which I understand is the pulse line?) and another line points to driver side and the line goes straight into the carb. that is the one I think may be wrong but a need some guidance
With everything hooked up will not run
If I unhook the fuel line going into the carb it will fire right up but die after a few seconds....
Thanks for any help that you are willing to provide...
    • By SkyPilot56
    • By Joe Breaux
    • By Chile
      Chile
    • By Ed Michael
      Subaru SxS.mp4
    • By Aaron Colona
