I have been searching the forum to find the how to on doing the manual four will drive, but can't find it. I'm sure I saw it before
I'm looking to buy it somewhere and the instructions or pictures for installation. Tired of the electrical one failing and getting stuck in Baja.
Ever since I replaced my box, waterproofed it, & fixed a short that I had in the fuse box it has worked flawlessley. I thought it was a cheap box, but it is actually very similar to the box on my Wildcat. The Wildcats are having a few issues with after submerging them in water. Obviously they also need to water proof them as well. Have you replaced your original box yet?
I have a brand new never used box. $125 plus shipping. It is a spare I still have from when I had my Trooper. Will be in Yuma Oct 18th mid-day, save the shipping!
rocmoc n AZ/Mexico
Well, immediately after purchasing a new 4x4 box it has been recommended several times on the forum to take the cover off & seal it with silicone.
Prior to my first 4x4 box going bad it would intermittently shift in & out. I just ignored it & figured it was the box. Then when I replaced the box the new one did the same thing. I noticed when I would turn on my headlights the 4x4 would really start acting up, so I figured I had a short or bad ground. I chased all the wires back to the fuse box at the passengers feet. When I pulled it
I have had failures in the 4X4 box also, so I tore it apart and rebuilt it and because the board was burnt, I redesigned the circuit to use FETs instead of the relay that is inside. Works well, but you have to rewire the switch or install a new switch. If any one is interested, let me know and I will elaborate, or if you want, for a nominal fee, I will rebuild yours'.
I have put a bunch of photos on google drive and if you want to look at them: https://drive.google.com/folderview?id=0ByQAhs0e-yF9X2VNSnFvekFMUjA&usp=sharing
I hear you guys but the manual option is where I want to go
Ya got another 1 1/2 weeks before I am in Yuma with my new box, LOL! Seems to me at one point Silver Bullet was selling a converison kit to the manual setup.
rocmoc n AZ/Mexico
I made my own manual connection, and got a cable at the local motorcycle shop. Where I am, it's difficult to get to a machine shop, so everything has been done with a hacksaw, file and drill. It's worked perfectly for well over a year, with no issues at all. You can see it here:
http://www.pauldaytonscifi.com/spotlight.html
You'll have to scroll down.
I did buy a lever from Lenny, which let's me engage the 4X4.
    • By Steve Waldner
