Hi, I am looking at a Mule as described above.
I do not have any experience with them. Is 900 a lot of hours? What kind of lifetime would you expect for the mule?
It is out of a rental fleet and I believe it has been well maintained.
Also, what do you think would be a fair price?
Thanks in advance for your advice.
  • 1 year later...
I just bought a brand new old stock 2011 for $9700 with four year warranty.
    • By mark walkom
    • By Kingfish
    • By REDfletching
