Hello
New to the forum.
I rescued what I was told was a 1994 2500 from rusting away next to a barn. Was told the motor runs but has water in the oil. I found some numbers stamped on the cross tube under the dash but all I can make out is KAF620C the longer number above is so faded it is not ledgeable. I have check other area but cannot find anything else.
Engine has a spline shaft. Need to try to verify the year.
Thank you
  • 3 months later...
The VIN on Mules are usually on a plate mounted to the frame at the front of the vehicle(mine is hard to see but is just to the left of the the plastic radiator cover) or sometime on frame near the middle of the seat.
    • By Joe Breaux
    • By Chile
      Chile
    • By Aaron Colona
