Kawasaki Teryxâ„¢ 750 4×4 Magazine Review
By fishhouse3
This machine is ready to go and needs nothing - just hop in and hit the trails! I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
By William Carberry
I have a MSU 500. I will start and run but requires basically full throttle to move. Does this machine have a drive belt? If so how difficult to change?
By johnpeter
2020 POLARIS RANGER CREW PRO XD 4000. FULL CAB KUBOTA DIESEL On Ebay
https://www.ebay.com/itm/166398698279?
By Matt Tousley
Looking to install wheel spacers on my 2023 Ranger 570 Full Size Crew….2” lift with a 28” tall tires.
Dealership tells me that the rig has 4/156 wheel pattern with 3/8x24 lugs but no one can tell me the bore size.
Also, any suggestions on which brands are the better of the bunch??
I appreciate any help.
Matt
By divecaptchris
I have a 07 700Xp Ranger, 320hrs, the machine started to develop a cough at 3/4 to full throttle. The Machine runs perfect other than that, and will cruise down the road at 5900 RPM with no issue. If you stomp the gas from idol or low RPM it wont start the issue until the RPMS get above 5K, if you running 3-4K it will do it as soon as the throttle reaches 3/4 open. I have changed the plugs and read them, look slightly lean but not bad. No codes except and code its had since I owned it for the transmission. Tested fuel pressure, its right on, looked for air leaks around the boot, found none. I also changed the belt just to make sure it wasn't a slipping issue that the tach didn't show it getting to the rev limiter. Any help would be GREATLY appreciated
