RiverPro
By Kingfish
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
By Michael Flippin
I have a 2023 T-Boss 410. The starter is just spinning but nothing is turning over. It was working fine and just stalled. Tried to restart and starter just spins. Thought maybe the interior of the starter broke. Ordered and installed a new starter and it does the same thing. You just hear the starter spinning but does not seem like anything is catching. I checked the gear the starter engages and that is clean and turning freely. Any idea what the issue could be?
By Wolfpaak
Pink Floyd quote/reference.
i am looking for a starter for my 2004 800 Renegade and apparently the place I dealt with before is no longer in business. Any help?
Thanks in advance,
Kenny
