IF YOU CAN FIND A SHOP THAT HAS A SONIC CLEANER, THAT WOULD BE BEST. ETHANOL IS PLAYING HAVOC ON THESE CARBS. NO, ITS NOT HARD TO REBUILD ONE BUT YOU MAY NOT GET THE RESULTS YOU ARE LOOKING FOR.
    • By GunnersTacklebox
    • By Edelbrock
      Thoughts?
    • By Bbicon
    • By Dennis
    • By rsar
