new to this site
By Dennis
By joynersfuntillitbreaks
so i just picked up a 2008 1100 trooper and iv ordered a few parts for it now and 99% of what i got fits perfect my issue now is my rear wheel hub is stripped out got a new cv and it fits great but i order 2 different hubs from 2 different places now and they are both wrong the spline opening is to small to fit the factory cv shaft and yes the shaft factory part #s are the same paid 250 for an original new replacement if anyone has anything that works to replace the original hub please point me in the right direction
By Kingfish
