just in stalled new rack and pinion in trooper out of 90s Subaru 4x4 . 4 to 1 racho setting still turn with 1 finger with no power assist.
That's great Dave I would like to see more ! Do you have any more pic Or can you tell us how you done it ? Or are you going to sale a kit I know you were the one on the fuel controller. Oh by the why long time no hear hope everything going good.
drill some new holes mount in stock location 2 u clamps cut ends off stock rack drill tap to fit new rack cut tie rod to lenth weld back. abought 4 hour job not selling kits.sorry.
Is that going to put the shortened tie rod on too much of an angle when the suspension is all the way up or down while turned to max to the left or right? You might also want to check that the ball joints at the other end of the tie rods aren't binding when suspension is at tis extents and your fully turned. When I re-did my steering, I dropped the shock so I could easily check for these potential problems. I ended up having to twist the arm at the wheel end so things didn't bind. Also if you have more right and left travel in your new steering box ( you'll need an extra 3/4" to do what I did) you can make the Trooper turn much tighter. With mine, I could make a tight U-turn and measuring 180 degrees across from of the inside tires tracks in the dirt I was at 16 feet. Really nice in the tight trails.
I'm starting to miss mine. I had all the hard work done. Went to trail riding dirt bikes, No more just sitting there and letting the ride do all the work. I definitely have gotten in better shape.
not sure of year 90s 4x4 is what was rote on it. got it off they shelf at junk yard. when you get one make shure it turns the right way.i maid that mistake on the first one an had take it a out an start over.
when u turn wheel that the rack travels to left an right when wheel turns left right .if the rack mounts behind the front axel it will be rong.
    • By Frank in MI
      Thanks for accepting me!
    • By Poppateets
    • By A P
    • By Xov
