I have a 2000 mule 2510 that idles great but spits and sputters and generally doesnt have any power. I have changed the plugs, cleaned the carb, changed the fuel filter, blown out the hose going into the gas tank, and drained the gas twice which had some sediment in it but still cant get it to run right. Any ideas?
Did you check your needles/jets for wear when you cleaned the carb? They may need replaced. Or check to make sure your choke is working correctly. It idleing fine but sputtering and not having much power suggest to me an air/fuel mixture problem...that there is an air restriction or fuel delivery problem. The only other thing I can think of is the coil not firing consistantly.
    • By Ed Michael
      Subaru SxS.mp4
    • By Aaron Colona
    • By Unhappy Kioti K9 Owner
