Mounting seats dump cart
xcycle
    • By Kingfish
    • By carl baney
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
    • By Retired Plumber
      The rear differential lock light is on and I would like to get it off. How do I do that it is a Coleman UTV700.
    • By djl
      Hi All.  The splines are pretty well worn where the rear driveshaft fits into the adapter (boss?) on the rear of the engine.  I have a new driveshaft / adapter / seal to install but am having difficulty loosening the nut holding the adapter onto the transmission output shaft.  I purchased a chain-type vice grip tool thinking that I could get it around the adapter to prevent it from turning but have not had any luck getting it in there yet (very tight space).  What approaches have you used that have worked?  Thanks!
