just received an email back from SB claiming that they have a 360 watt power steering kit .... what do you all think i sent them one back wanting manufacture and all of the motor it would be interesting if it was a 360 watt motor it should turn the trooper even with the lockers locked in ... super at is only a 220 and 650$ SB 360 watt claimed and 1200 .... so for the extra watts if true i would do it possible that and how do the ones from super atv steer with lockers locked ...
no shit thats awesome i m all about getting the most power and easy drive ability it is a true work out driving the trooper locked up lol not that i mind i m 27 .... but it would be nice to go slow and not get a full arms and chest work out
i talked to franky from SB there computer are now water proof all brackets bolt right up and i m going to to get the new up graded rack if i get it but will have to buy a new lower steering shaft because the size is now larger it is suppose to be done this week
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Cletus
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
