I was going to put heater in my trooper. so I cut the hose that tees at water pump an goes back to back motor.an put shut off in it.. with it shut off motors runs about 15 degrees cooler. because that water water never get to the raidor it just goes in circle.water pump to motor. might help you all. plug that line.
    • By ToughLuck
    • By CapnWalleye
    • By CapnWalleye
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
