:( :blink: I have a mule that I had to start pulling the choke to keep running at about 75 hrs. I have been working on it and its about to drive me crazy. It will go for ways and start running out of fuel. I have cleaned the carb 4 times, replaced the fuel pump, blowed all the lines including the vacum, replaced the fuel and added sea foal additive. The harder load its under it seems to be worse. I even replaced the coil to cover the bases. I am 99% sure its running out of fuel. I have checked the float and needle to be sure its working freely. I really would appreciate any ideas on fixing it. Thanks Richard
I WOULD START BY CHECKING VALVE SETTINGS. SECOND, HOW OLD IS THE FUEL IN TANK? THE ETHYNOL IS PLAYING HELL ON CARBURETORS. I WOULD HOPE WITH 75 HRS. ON THE MULE IT WOULD NOT BE CARB DAMAGE BUT YOU NEVER KNOW. 3RD. IS THIS MULE UNDER WARRANTY?
  • 1 year later...
    • By A P
    • By clint501
    • By rsar
    • By TjB
