ok so excuse me for sounding dumb on this but I have read on here before about toe adjustment and how you can make the trooper turn better. I understand how and alignment works being an auto tech. So basically you wanna turn the wheel right or left and adjust at the steering box first to get the max left and right with out binding correct?? Then center your steering wheel and adjust with the toe bar on the suspension so when your steering wheel is striaght your wheels are not toed out????
Not absolutely sure of what you said, but the turn to the right and rotate the hub is a CHECK to see if it is binding, if it is binding badly, you can't turn the hub and if you were driving, it would be felt in the steering wheel and probably damage the CV, If it's binding at all, you'll feel it as you turn the hub, --THIS A TEST-- But if it does need adjusting & mine did, that's how I did mine, another point not mentioned, IMO, you need to see that the flat, long, thick nut is tight against the yoke end and IMO, square with the shaft so that is has maximum interface contact with housing. it is the end of travel STOP. I went so far as to file mine to get an extra 1/10 of a turn. It also is what keeps the boot out there close to the yoke.
    • By Grant
    • By Ductking1
      I recently purchased a 2024 Hisun 550 Sector from Kreps Service Station and am having issues with the gear selector, I am doing as instructed in the owners manual but the shifter acts like it is binding or the button lock isn't releasing, the shifter will not move, I have to wiggle it back and forth while pushing hard on the brake and if it's in park or reverse it's nearly impossible to get it to move, I contacted Justin Krep and he says this is normal with these machines, I find that hard to believe, I've owned many utvs and side x sides and have never had this kind of issue with any of them, any help with this problem would be greatly appreciated.
    • By Texjpr
      2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass  switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
