No overheating, but did add a turbo and any performance engine I have built benefits from a cooler running thermostat, less chance of detonation. Just thought I would ask before I remove the old one to cross it with one that will fit.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Jacob E freeman
    • By mark walkom
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
