Tires
By JimG
By mark walkom
By Guest
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
