Tires
By mark walkom
By Jason S
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
By BernieG
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
By Pilot1996
When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
