Looks like same pattern as what came on my t2 stock (far east) it was good for all around and being light. I think I'll look for lighter tires next since mine is really heavy at about 40 or so lb each. Outlaw 2 29.5x9.5x14 front 29.5x11x14 in rear
Sent from my SM-N900V using Tapatalk
Plumber, where you looking at price? or the best tire? also what size did you need? The tire for the money the Outback is a 6ply tire and has a larger lug depth and a thicker side wall, where the CST Ancla has a thinner side wall and smaller lugs.
The two best tires I have used is the GBC Mongrel and the STI Roctane
Mongrel :
http://www.gbcmotorsports.com/kanati-mongrel-p-216.html
Roctane:
http://www.stitireandwheel.com/2012/12/roctane-xd/
Tms utv,
I agree about what you said about outlaw and that they do very good for flotation as well. I have done lot of research on utv/atv tires but somehow I never heard about those tires. I even never heard of them before.
nocturnalsixer,
You have never heard of the Mongrels or the Roctane? They are definitely the ticket - I prefer the Mongrels, but from what I have heard from people they like them both. I havent really got a chance to try the Roctanes in all the terrian that I have with the mongrels.
    • By mark walkom
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By Jason S
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
    • By BernieG
    • By Pilot1996
      When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
