So while building my cage I made one bend a couple of degrees over. It was literally 3 degrees off. So I wedged it in my tube bender, had my wife sit on it while I pulled like hell, and several attemps, and got it within one degree. So with my wife (130lbs) and me pulling my 185lb ass off all it left was a couple of small dents in the 1 3/4 .095 wall hrew I am using for half of the cage. The other half is .120 wall DOM.
So once I got done getting it to shape I thought to myself that I need to see what happens if I try it with the stock cage. I wanted to know if all this effort is worth it. Well, I finally got around to it today. This is what happened with just me pulling (no wife for extra leverage) and with half my effort:post-867-0-44270600-1396914922_thumb.jpg
If you ever had a endo in a trooper you would not walk away. Can it handle a flop or a slow sideways rollover... Probably, but an extreme impact and it will wrap around you like a street taco.
wow Ya I just had the front and rear welded together if I was as crafty as you or some otheres I would stotally rebuild it I was shocked how thin it was the new tunes I added are 2-3 times thiker and feel great with the xtra wieght off the back
Yeah, when I take my rear seat off mine is so much less tippy. I think I estimated about 85lbs for the stock rear cage and spare tire. I run superatv dominator tires and don't even work l worry about running a spare tire. The stock tires are paper thin.
    • By D MAYNARD
    • By Roadstar515
      Regards, Rick
    • By Jacob E freeman
    • By Browner010
      Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
      Any Ideas what to look for would be appreciated.
