Had to tear down my rear dif and was wondering if anyone knows the exact bolt size length of the ring gear bolts.
I know it is a m8-1.0 thread pitch just not sure of length.
looks like you may have got lucky...I can measure what we put in, in the AM...I know they can be longer than original and not interfere...we replace with a higher grade bolt larger head size and loctite,normally re-shim at the same time
Found the bolts I needed at Fastenal. 12 bolts was 8.44. This is a 10.9 grade bolt. Allen head bolt also. I'll reply with how they work out.
Bolt measurements are m8x1.0x16mm.
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By camojay
    • By GaryC
    • By lowgear52
