Manual 4x4
By Travis M
Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
By Fishing Wiskers
By dave pasch
Has anyone trouble shooted this transfer case? Full 12v to switch and case. No action inside case.
Thanks Dave
By hdtran
By Hunterman22
This is the 2020 updated version from the previous 2009 version. I do not know all the differences. I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
