I just bought a 1999 Mule 2510 with 4XX hours on it with a twin 650. Runs well but I have to hold the brake and stomp the throttle to get it to idle down so I can shift into F or R w/o grinding. When it idles down it shift fine. Thoughts?
  • 4 weeks later...
I have seen this often on the older mules. Usually you have to replace throttle cable to correct problem. It may be sticking and not releasing all the way, thus tap on the throttle and it comes down.
    • By Ed Michael
      Subaru SxS.mp4
    • By Mike Jenkins
    • By ToughLuck
    • By Paul L
    • By CapnWalleye
