Guest Lenny
I may have one. Had a new one that I sold on Ebay. Guy said it didn't work so I'm refunding his money. I'm thinking it's ok and may just be something simple. Will check it out when I get it back. I'll let you know.
For the starter solenoid you can use a 96 Geo Tracker.. Replaced my solenoid with one. Bolted right up... 1.6 GEO motor ..Make sure you check it out before buying for the starter motor part. I do not know if it spins CW or CCW plus I did not count the teeth on bendix. The solenoid is 78.00 at Advance.. 25.00 For used starter at junk yard.
I recommend the use of an interposing relay when you get things back together, the long run and small wire from key to solenoid limits the current and before I put one on my trooper, I could hear the solenoid come in, but the starter didn't spin, after I put the relay in, no more problems. Take your starter apart and clean and lube it and clean the commutator and then put it back together, that could be all it needs.
Thanx kinarfi I do he whole relay thing over a year ago u helped me out with it. I pulled the starter out and tested it on the bench it didn't turn ova everytime I gave it power and when it did it was really slow
  • 5 months later...
Did the interposing relay, but still had problems. So i:
removed starter and dissassembled. water had gotten in and one brush was seized. easy fix.
Who designed the intake? idiot. flipped it upside down. Now, i can get to the starter easily, plus the MAS doesn't get crammed with mud.
Moved the starter cable from the cutoff switch to the battery direct. Why complicate things?
Everything works good so far...
    • By Ken rung
    • By rocmoc
      rocmoc in AZ/Mexico
    • By SouthernGypsy
    • By hisun junk
      As I tried to do a conversion with the Yamaha 660 motor, I realized the 660 was never fuel injected so it would not work for the fuel injected hisun motor swap. But the good thing is the hisun 750 motor is a clone of the 660 Yamaha but with the components for the fuel injection (cam/crank position sensor). So that left me with a new rebuilt Yamaha 660 and still a broke 750 hisun motor. I took apart 750 think the timing chain had broke from all that I've heard about these motors. The chain was not broke, but just off cam and crank gears! The chain tensioner was at fault!  I've ordered Yamaha 660 replacement parts, chain, two exhaust valves (which got bent when chain came off while motor was spinning) and seals. The piston has 2 little nicks where it had hit valves but no damage otherwise. The head is being redone at the machine shop and I'll be putting it back together in the next couple of weeks. Also I finally tracked down a Service Manual with all the info on the 550/750 Challenger.
    • By se3388
      Steve.............
