I started my trooper today prior to head out to the trails. Started with easy. Filled gas tank. Now won't start. Read not to over fill tank. Drained tank till half full. Now won't start.
what do I do or what possibly could have happened?
Can anyone help? I think I overfilled my gas tank. Trooper was running great. Filled gas tank. Started but ran really rough for approx 1 min. Now won't start. Drained gas to half tank. Still won't start.
have I done any damage? If so what? How do I trouble shoot?
sound like you got some bad gas, drain the tank and go get some new fuel some where other than where you got it before, flush the lines by pumping fuel into a can,, may need to pull the injector rail and clean it if you got fuel with sediment in it, the injector rail is dead ended, so if crap got in, it's stuck there, I drilled a hole in the end of mine and put a small fitting on it to allow the fuel to go back to the tank.
ps, drain the fuel into a glass bottle so you can see if it has crap in it.
Guest Lenny
if you put a hole in the far end of the fuel rail, it has to go back to the regulator to maintain proper fuel pressure in the rail. Proper set up is for the fuel pump to feed into one end of the fuel rail with a line going from the other end to the regulator. The regulator wants to be after the fuel rail. Joyner has it set up wrong from the factory.
this may not sound too technical...but have you confirmed that your fuel pump is running? second what year is your trooper?.they do have slightly different start up actions ....the older ones had a fuel pressure gauge at the left rear of the engine...that should show somewhere between 45-60 psi when the pump runs in pre start up mode (the new troopers use a different style regulator and no gauge) poor fuel..yup have run into that,but as far as setiment plugging thing up,hopefully your fuel filter would catch all/most of that...but plugged filters happen...finally when you say "wont start"..exactly what happens...you turn the key to the first position,wait for pump and fan (possibly) to run and the gauges to sweep...(you should then have fuel pressure at the gauge) when that is complete you turn to start position...cranks well but wont fire up?? try the same sequence with your foot slightly on the gas pedal...try again... I know this sounds simple,but sometimes its the simple things that keep one from starting ...just my 3 cents...Hardy
  • 5 months later...
I had my carbon canister get loaded up with fuel and plugged. No air was getting into the tank, creating a vacuum. Try unscrewing your gas cap.
it's stupid, but worked for me. I chucked my carbon canister.
This happens a lot with the new Chery powered rails (Renli) that carbon canister is below the fuel level in the gas tank. Once that canister is saturated with fuel the engine wont start, it will start if you pull the vent line from the intake side but with out a filter you'll be pulling unfiltered air into the engine. Opt. 1: remove carbon canister plug all lines. (Tried this but engine would hard start and rough idle also not emissions compliant) Opt. 2: Vent intake manifold line to it's own filter and plug carbon canister (This works just keep it high and dry, still not emissions compliant.) Option 3: This a mechanic friend told me and after I was like duh, just put a longer hose from the gas tank to the carbon canister and put the high point higher than the high point in the gas tank. (This is emissions compliant) In cars and trucks the carbon canister is mounted above the fuel level in the tank and in Jeeps and SUV's it has an anti siphon valve to keep it from contaminating the canister. Also if the canister has been filled with fuel it takes a few hot days with all the lines off of it to dry it out.
    • By aefron88
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
