I recently aquired a 2002 Kawasaki Mule KAF950-A3 diesel 4x4, however there is a hole in the case exposing the rear differential. From what I can see there is some damage done to the rear diff inside, also it does not go into reverse. So I went online pricing parts & it looks like it's gonna be a pretty hefty bill, not to mention what i can't see inside. So I am trying to find a used transmission if somebody has one or knows where to get one. Thanks for your time.
    • By Paul L
    • By Grant
    • By D MAYNARD
    • By TjB
    • By rsar
