    • By Xov
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By NCPonyboy
      Hello, new Hisun Axis 500 owner here. I have a 2020 in the Mountains of North Carolina. It runs fine and I enjoy it but it seems to struggle on the hills. Granted I have one that is pretty steep but you could get out and walk faster than it goes up. I sometimes wonder that if I had anything in the bed it might not make it. So first question is, is this normal for these? Second question is, is there anything I can do about it? Maybe a power adder or chip tuning?
      Appreciate your thoughts
    • By Beardy13
      I own a LM700 with the Subaru V-twin, while I was checking game cameras today I noticed my Landmaster started struggling and even stopping going up an incline or steep hill. I’ve gone up these same inclines and hills for the last three years with no issues until today, if the ground was level it would run perfectly fine but as soon as I came upon an incline it was like it instantly lost power and all forward motion going up hill. Any advice or ideas would be greatly appreciated!
    • By rob1845
      I lost my  Auxiliary lights and power steering and it is flashing area code F0014
