It's not really a valve, it's just a chamber where the oil mist can separate for the air and the oil drains back into the pan, there shouldn't be that much air travelling through it unless you have serious blow by from worn out rings.
That caused by poor air filters letting very fine dust to pass and that wipes out the rings. OR so it was for me.
hello Kinarti
I live in grants pass,ore @ about 3500rpms it sounds like very noisey lifters at first it was only while climbing hills ,now it is any time @ 3500rpms
I have had the valves or shims adjusted and he did not find the problem
do a compression check and see what you get, another more difficult is the blow down test which is build and adapter and blow air into you cylinder, I ran with a bad filter and wiped out my rings and I drool all over my separator, I later made my own and I think it's better and cheaper.
    • By Smittay
      I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
    • By Jim Kessell
      Hi All
      Jim
    • By bms stallion owner
    • By Ken rung
