    • By Bobhoops
      Where can I purchase a spare tire for my 700 utv? Thanks
    • By Mark T
      MY 400 is gutless. I would like to know if I can upgrade to a larger engine ?
    • By PaulB
      Just wondering how some of you mount your spare tire. I’ve seen the mount that uses the receiver hitch but don’t like that because it looks like it would get in the way of loading and unloading things into the bed. Not even sure if the tailgate drops down when using that sort of mount. I was looking at an in bed mount that has three carriage bolts, 1 to the bed bottom and 2 to the bed side but concerned that the polymer bed might not stand up to that.
      What did y’all do?
      PaulB
    • By Owenhacker
      So I have disassembled and installed a new wet clutch all new bearings, regreased primary and once I got it all back together it starts and dies as soon as I put in gear.. took apart twice to make sure everything is correct. Need help
      IMG_9111.mov
    • By Dreaded
      This tboss 410 started having a problem with I think clutch not releasing. If you have it in forward with neutral safety disabled and try to turn it over, it will try to move forward. Neutral does work correctly.
      What I was told occurred was he was trying to back up a hill and was trying to pull a load. He said that it all of sudden died and would not go into gear. To get it back he disabled the neutral safety and started engine and drove back but had to switch to neutral to stop.
      Is this going to be the centrifugal clutch on the drive belt or could it be something else?
