If you pay attention to the sound of your squeaks, there is a certain sound that the frame makes as it gets ready to break. My squeak finally quit, the bracket that the A arms mount to completely separated from the frame, I managed to wrap a ratchet tie down around it a few times and pulled it back close to home position and headed for the trailer. I took some photo and they are in my gallery.
After straightening the bracket and welding it back in and mounting the A arms back in, I was adjusting toe in and I notice I had some slop in my tie rod end, rather than just replace it, I ground of the little spot of welding and screwed the top down tighter on the ball and tightened the nut up that holds it to the hub. Greased every thing and it's ready to go, as soon as I rebuild my shocks.
  • 2 months later...
Had the same prob. Nearly lost my rear swingarm on an uphill loose gravel climb. luckily, i knew a guy with a 70's landcruiser jacked three feet high and a 10 ton mech whinch. He got behind me, lifted my rear end off the ground and drove 20ks to get me home. Felt like i lost my virginity with that one, haha
    • By Bjabbarw
    • By TPlummer
      Any ideas on using sound deafening mats? Have they helped with the noise? Worth it? These side by sides are so loud!
    • By hdtran
      That's the question! Or, if you want to add details:
      (a) How do you use the UTV? (roads? off-road to get to trees? etc.)
      (b) If you are wearing a helmet--how frequently? What type of helmet?
      My own answers: (a) Most of the time off-road to get to downed trees, cut the trees to logs and haul the logs back for splitting. (b) Very rarely, a ski helmet and not a motorcycle helmet.
      A while back I was looking at an auction UTV plow and the mounting of it.  Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV.   I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn.   I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place.   The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
      Anyone ever try this for a front mount?   It would be close to  this one that is for sale on the net.  It is supposed to fit a KFI plow mount.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
