Comando key blank
By Grant
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By hetovi
Hello everyone.
I recently bought a Can-Am Ryker and I'm looking to customize it with some accessories. I’ve seen a lot of options out there but wanted to get some recommendations from fellow riders.
What are the must-have accessories for comfort, style, or performance?
Specifically, I'm considering a windshield and better footpegs—are these worth the investment?
Also, any thoughts on storage solutions like saddlebags or rear cases?
Would love to hear your personal experiences with any mods you’ve done.
By owencole15
Massimo 500 will only crank when I jump solenoid with screwdriver cranks right up and runs great. But won’t start with key doesn’t do anything when I turn the key. Only thing it does is power everything as in dash and fuel pump then have to jump solenoid to crank up and drive.
