Three-round, three-week event begins Thursday, November 27thNovember 24, 2014 â Boise, ID â FLY Racing and Mad Skills Motocross 2 (iOS/Android) have joined forces to bring you the first-ever FLY Racing MX World Series! The gate drops on this three-round, three-week event this Thursday, November 27, and runs through Wednesday, December 17.Fight for your line [...]
Related posts:
  1. GBC Motorsports Offering Over $50,000 in Contingency for 2014 WORCS Racing Series Anaheim, Calif. – January 9, 2014 - GBC Motorsports...
  2. Nic Granlund Tops Podium at The Dirt Series Nic Granlund on the top step of the podium...
  3. GBC Motorsports Offering Over $200,000 in Contingency for 2014 GNCC Racing Series Anaheim, Calif. – February 18, 2014 - GBC Motorsports...
View the full article
    • By Mike McDonald
      I have a 2014 Intimidator and need brake pads and calipers. The price for pads and rotors are outrageous through the dealer. I have heard Intimidator used the brake assembly from a compact car when first building these UTVs.
      • Can anyone tell me of a less expensive source to buy brakes for Intimidators from,  or
      • Can anyone furnish information on what make and model vehicle Intimidator  used their brakes from?
      Thanks so much for any support you can provide me on this topic.
      Mike
    • By tskm
      Tom
    • By Kingfish
    • By Ridge Runner
      i have a 2019 Coleman 550 Outfitter.  The tail gate has a pin on each side, that snaps into latch blocks that are mounted on the inside of the tail gate opening.  There are two M6x16 pan head screws(bolts?) that hold the latch blocks in place.  The screws enter from inside the bed body, and I can’t figure out how to access them.  This is right by the tail light assemblies.  I tried taking a pan head screw out of the fender lip, but found out there is not a nut firmly inplace, to hold the pan head screw in.  Bottom line I’m making it worse.
      coleman was no help.  If I could figure out how they attached the tail light, then maybe I could put the latch screws in through the tail light hole.  Any ideas?
      thanks
      Ridgerunner
