ATVMX Makes Historic Announcement with Addition of Daytona as Opening Round of 2015 Championship
By TexAcoon
I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
By Mike McDonald
I have a 2014 Intimidator and need brake pads and calipers. The price for pads and rotors are outrageous through the dealer. I have heard Intimidator used the brake assembly from a compact car when first building these UTVs.
• Can anyone tell me of a less expensive source to buy brakes for Intimidators from, or
• Can anyone furnish information on what make and model vehicle Intimidator used their brakes from?
Thanks so much for any support you can provide me on this topic.
Mike
By tskm
Tom
