King Shocks, Eugenio, Vildosola, Covey, Gera All big winners at 2014 SCORE Awards Night
Jimco repeats in Original Chassis Manufacturer points; Kroyer repeats in Engine Builder pointsKawasaki Motorcycle Manufacturer point champion; 22 SCORE Milestone award winners honored SAN DIEGOâKing Shocks, Steven Eugenio, Gus Vildosola, Steve Covey and Tony Gera were among the big winners Saturday night as SCORE International officially concluded the 2014 SCORE World Desert Champioship with [...]
Related posts:
  1. SCORE International removes SCORE Reno 500 from 2014 SCORE World Desert Championship slate RENO, NV â SCORE International, based in Reno, has announced...
  2. King Shocks Reign Dominant at 2014 King Of The Hammers GARDEN GROVE, CA February 13, 2014 -Year after year, the...
  3. King Shocks 2014 King of the Hammers Race Recap King of The Hammers is known as being one of...
View the full article
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By boydog40
      thanks guys
    • By KimAC
      I need a pair of front shocks for a Landpride Treker 4200NT, from 2005?  Does anyone know of a good salvage yard - or another source?
      -Kim
    • By Reynolds Rocket
      I have a 2017 Intimidator XD4 800cc 4x4.  It will run great and then it's like it goes into safe mode and only runs on 1 cylinder.  It's not fouling out the plug when it happens.  Some times when I stop and restart it, it works fine.  First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
    • By lmarkie
      I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
      Only problem is the exhaust exit is toward the back seat instead of out the back.
      Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
      Any thoughts?
