KC HiLiTES
Invite your friends to get free products. It's that easy.
Did you already make your Christmas list? Did it get eaten by your neighborhood pup and never make it to the North Pole? Never fear, KC HiLiTES has you covered and the odds are in your hands! (well, yours and your friends)
We have four tiers of prizes that you will be able to earn for yourself depending on how awesome all of your friends, family, followers and groupies are; because it's up to them to click on your unique link (you will get this once you sign up) and sign-up.
Visit http://www.kchilites.com/special-offers to start winning! Or if Facebook is your preferred method to enter, you can start here as well (this link will not work on mobile, please use link listed above): http://woobox.com/z3hhqx/cqfnac
chirstmas-woobox_reveal_final_800x800.jp
FAQ
1. Is cheating allowed to gain entries? No, our robots will catch you :)
2. Will I win all four tiers of prizes if I get the max amount of friends to sign up? Sorry Mr/Ms. Rockstar, you will only receive 1 prize; the highest tier that you earn up to.
3. How easy is it for me to win free KC HiLiTES products during this 2014 holiday giveaway? So easy! Simplest process you will go through all year! Will never get easier from here on out! Go to http://www.kchilites.com/special-offers to sign-up, get your unique link and share with friends. As your friends sign-up you win stuff!
4. When will I receive my prizes? Within 2-4 weeks of the contest end date (giveaway ends on 12/31/14)
5. So it's that easy, huh? Yep!
Connect with KC HiLites
Follow us on Facebook at www.facebook.com/UTVGuide
YfTPNnYbM6U
View the full article
    • By mark walkom
    • By hdtran
      That's the question! Or, if you want to add details:
      (a) How do you use the UTV? (roads? off-road to get to trees? etc.)
      (b) If you are wearing a helmet--how frequently? What type of helmet?
      My own answers: (a) Most of the time off-road to get to downed trees, cut the trees to logs and haul the logs back for splitting. (b) Very rarely, a ski helmet and not a motorcycle helmet.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
    • By strike250
      Matt
    • By Ronald
      I just purchased an Axis Pro 750 from Lowes.  I have two questions not covered in owners manual.  1:  In the glovebox there is a 12V connector, it is HOT with key off, is that for a battery maintainer to be plugged in or what is the purpose?  2:  In the instrument cluster there is a digital read out for hours, miles and odometer,  there is also a digital readout that is flashing, it can be adjusted and looks like 1 - 24  what is it?
