CASTING CALL
ONLINE OFF ROAD REALTY TV SERIES
Do you have a reality show idea based around your passion for off roading and the lifestyle you live?
Are you creative?
Do you think outside of the box?
Are you a character and willing to share your life for all to see?
Do you compete in any type of off road racing? (Not necessary)
Have a story that just needs telling?
We want to hear all your ideas.
We are is looking for talented individual’s and personalities like yourself who may have an idea or want to star in an off road reality series based around off roading and the lifestyle we love.
If you have an idea or know someone who wants to be in reality show contact us with your pitch.
Guidelines for presenting ideas
• Video submittal: will be no more than 2:00 minute long describing your pitch idea.
• Written submittal: describe in 300 words or less your concept idea and why you think your idea will work for reality.
• Individual Casting Calls: individuals who think they have what it takes to be in an off road reality show must send a bio and a brief description about yourself and why you want to be a part of an off road reality show.
Email all submissions to:
[email protected]
Please submit all videos using
https://www.wetransfer.com
If your pitch is selected we will contact you and discuss what the next step will be.
    • By Greg Kilgore
      I did compression test.
      How hard is it to replace?
      Advise?
    • By Michigan sport.
      I'm sure many of you are aware of Michigan's emergency brake requirement.  I'm wondering if anyone has a good solution.
      Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to  the Maverick sport rear mounting bracket?
    • By Kingfish
    • By Farid
      Hey there,
      I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
      Also, if you’ve got any other parts for this model, I’d love to hear about them!
      Thanks a lot!
