Security against Theft - GPS tracker?
By Kingfish
By chuck92308
I am throughly discussed with the 800sx. It has a lot of suspension cracking and squeaking from the suspension/shocks. Also been to the dealer 4 times for excessive drive clutch/belt squealing. They have no clue and they have (supposedly) changed both clutches and drive belt. Anyone having any of these issues.
By Woody77
By Farid
Hey there,
I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
Also, if you’ve got any other parts for this model, I’d love to hear about them!
Thanks a lot!
