Silverbullet
It could be 2 things 1 the 4x4 switch 2 bad 4x4 actuator.With the ignition switch in the run position when you move the 4x4 switch you should hear a buzzing sound from the front differential switch.If you hear the buzz than the switch is ok.To check if the the actuator is to pull out the 4x4 actuator off. There is 1 screw on the driver side and 1 that you have to remove the tunnel by the shiftier to get to the other screw out.Once you have it out plug in the wiring and move the 4x4 switch take the cover off the actuator and see if the plastic screw moves than give me a call.928 344 2117
Thanks Frankie
    • By staind
      thanks Dan D. aka staind
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Robbie Wyre
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Gerals
