Need some help!! Pulled the motor and tranny out this past weekend to replace the clutch, got everything back together now wont start?? Not getting any spark at the plugs, but I am getting power to the ignition coil. Has anyone had to replace the ignition coil on their trooper? Tested the coil with a volt meter but not 100% sure what ideal readings are for this particular coil? I know its not a fuel issue, pump is good and plugs are wet and getting fuel pressure. Any advice would be greatly appreciated!
agreed with bigdan..check crank sensor plug in...also double check correct wires are plugged into coil,if I remember correctly the crank sensor plug will reach and plug into the coil and vice versa..
if coil was functioning correctly prior to pulling engine,I would look really good at wiring,grounds etc before changing coils just my 3 cents Hardy
    • By KWinTX
    • By Wolfpaak
      Kenny
