I've got a 2006 mule 610 4x4 that was inherited by my wife. It has 1300 hrs on it & was in pretty bad shape cosmetically. It did however run but was hard to go into gear. It never seemed to get up to max speed.
I cleaned it up & replaced a few plastic parts, seat covers plus the front mounted winch. It ran for a few miles, then when I stopped & put it in reverse it would not move. You give it gas & it seems like it has the brake on.
I pulled the primary cover off & the primary clutch turns but the secondary clutch will not move when you try & turn it by hand.
Any thoughts?
  • 6 months later...
      Is there a way to bypass the seatbelt speed limiter?
    • By BigWave
      Bigwave
    • By Mike Jenkins
    • By Xov
    • By Paul L
