hey everyone were are you guys all buying parts. Silverbullets, JMC, or other. I wanna go threw my front end new wheel bearing, wheel hubs that the axle splines mate to ball-joints and tie rod ends. nothing is broken just wanna freshn it up... Also has anyone found a cross number for a master cylinder fro the brakes and if you replace it do you do them as a pair?? None of this really needs to be done except the bearings little sloppy. Also id sell it for 5000 if any of you guys want it
silverbullet
I have a new engine 1100 cc long block.Its a complete engine less intake, exhaust,fly wheel.2450.00,Plus free shipping.You will be buying from a joyner dealer who stands behind the warranty.
Thanks Frinkie
Silverbullet
Warning some one is telling customers that the rengade rear reducer} differential will work in a commando is not correct.The ratio is different then the front differentail on the commando.So if you use the 4x4 your front wheels will be going slower than the rear.That not good!
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
