my 2005 3010 mule with the 620 in it decided it was tired and went to knocking. i have ordered the predator 670 v twin that should be here tomorrow for my replacement motor. as far as the clutch i am looking at the comet 780 for around 280.00. has any one ever did a motor change that might could give me any advice on the project or clutch.
thanks robbie
  • 2 years later...
Predator's are pretty good, lasting engines. Most people i know dont swap engines,  but just rebuild it.
A lot of the times, Piston slap (knocking):  Piston slap occurs when the gap between piston and cylinder is too wide. Through wear and tear, the gap between piston and cylinder becomes wider. The noise associated with piston slap occurs in association with the perpendicular movement of the piston.
just a little lesson ;):)
    • By hisun junk
    • By mark walkom
    • By Josh5696
