New (used and abused) 2008 Joyner Trooper T4
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
By Havoc321
I’m looking to have my 2022 800sx fit in the 10’ garage of my toy hauler. I thought about removing the dump bed, so I wondered how far the dump extends beyond the tires. Thanks!
By great8redsfan
Okay folks. I have a low power issue. Been like this for a few years. Place I work at bought 3 and all have lost most of the pulling power. They gave them away after local shop worked on one for 3 months and it had great power for about 1 month and then crap. They replaced throttle body, fuel injector, spark plug and IAC motor. Seat belt switches have wires cut and left open so no seat belt warning light anymore. It revs to 6k rpm in neutral but when put in gear and take off in low it just doesn’t seem to want to go anymore. Running 93 octane fuel with Stabil. Any ideas greatly appreciated. I dont have a scan tool but no codes on dash. If held to floor it pops a little and runs almost 5K rpm but if I let off pedal about an inch it smoothed out and revs up to 6k rpm.
By johnpeter
RZR 1000 XP EPS - Rocks & Trails Edition 2020 On Ebay
https://www.ebay.com/itm/355474995514?
